Script to Monitor Remote System - - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Script to Monitor Remote System - (/showthread.php?tid=4280) |
Script to Monitor Remote System - - jamesng - 03.10.2022 Hi I have a script which I use to monitor the zones in a remote alarm system. It's a looping script which processes the data coming in from a socket connection. I need one instance of the script running continuously. What's the best place to locate this (script below) - is it as a resident script with a 0 interval time or as an init script or somewhere else? Many thanks in advance Kind Regards, James Code: -- Initialise socket connection
if not sock then
require('socket')
sock, err = socket.connect('192.168.1.100', 2401)
if sock then
sock:settimeout(1)
log('Error connecting ' .. err)
sleep(5)
-- Process data received
if sock then
while true do
rec = sock:receive('*l')
if rec then
data = lmcore.hextostr(rec, true)
st, addr, len, cmd, event, id, area = data:byte(1, 7)
if (event == 0) then
log('Door open in Zone ' .. id)
log('Door closed in Zone ' .. id)
endRE: Script to Monitor Remote System - - admin - 03.10.2022 You can make multiple copies of this script as a resident script with sleep time set to 0. init script should not have any blocking or long-running parts. Also non-blocking connect should be used and possible errors during receive should be checked: Code: if not sock then
sock = require('socket').tcp()
sock:settimeout(1)
res, err = sock:connect('192.168.1.100', 2401)
if not res then
log('connect failed', err)
sock:close()
sock = nil
os.sleep(1)
if sock then
res, err = sock:receive('*l')
if res then
-- parse res
elseif err == 'closed' then
log('connection closed')
sock:close()
sock = nil
endRE: Script to Monitor Remote System - - jamesng - 03.10.2022 Thanks for the script refinements. I’m still a little confused - if this shouldn’t be run a resident or Init script then what type of script would you suggest I create this as? Kind Regards James RE: Script to Monitor Remote System - - admin - 03.10.2022 I've never said it shouldn't be a resident script. Resident script is exactly what is needed for such task. RE: Script to Monitor Remote System - - jamesng - 03.10.2022 But won’t multiple instances of the same script running cause issues / use up all the available device memory? What time interval would you suggest or modifications to the script to avoid the above? Kind Regards James RE: Script to Monitor Remote System - - admin - 04.10.2022 You can run multiple instances without any issues. Sleep interval must be set to 0 in this case. Most of the time the script is in a suspended state waiting for data to arrive so it does not consume CPU resources. RE: Script to Monitor Remote System - - jamesng - 04.10.2022 Thanks for clarifying. Many thanks. |
