Modbus TCP datapoints limitation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Modbus TCP datapoints limitation (/showthread.php?tid=4287) |
Modbus TCP datapoints limitation - Ceros2112 - 07.10.2022 Hello, what are the limits of Modbus TCP in lm5lp2? For example, I have one building with at least 1000 modbus tcp coils, is one lm5 capable of handle that? Thank you for your help, I'm sorry but I can't find any answerÂ
RE: Modbus TCP datapoints limitation - admin - 07.10.2022 Depends on how often you want to read this data. If coils are in a continuous range it is possible to read all at once instead of one by one. RE: Modbus TCP datapoints limitation - Ceros2112 - 07.10.2022 They're pretty much 90% lights (there is a working PLC installed that actuate the lights) controlled with presence/light detectors, basically lm5 will be used as a SCADA (supervision, schedulers, ecc...) and as a gateway from KNX to the PLC. I think we don't need extreme speed in reading, but we do certainly need speed when we write data to the PLC, can it be a problem? RE: Modbus TCP datapoints limitation - admin - 07.10.2022 If PLC can handle multiple connections then it should be fine. RE: Modbus TCP datapoints limitation - Ceros2112 - 07.10.2022 2 at best, I suppose that you're suggesting to handle reading and writing as two separate modbus requests, right? |
