Irrigation scheduled script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Irrigation scheduled script (/showthread.php?tid=4299) |
Irrigation scheduled script - benanderson_475 - 16.10.2022 i have some irrigation to controll with feedback from som moisture sensor, i want to run a scheduled script in the am at say 5:00 to check if moisture is below a setpoint then switch on irrigation for 2 hour if required each day at 5am when script runs if is dry then switch on 0/5/1 (bool) how is the best way to manage the switch off later?, make another scheduled script for 7:00am with switch off? i also need a way to include some offset so i don't over water etc or maybe there is a better way like make the off command an event script form the moisture sensor? RE: Irrigation scheduled script - admin - 17.10.2022 You can have both scheduled and event script for this. Scheduled script guarantees that the irrigation is turned off after 2 hours. Event script can turn it off earlier if the moisture level becomes high enough. |
