javascript lp file - Printable Version
+--- Thread: javascript lp file (/showthread.php?tid=4306)
javascript lp file - jmir - 20.10.2022
Is it possible to use javascript grp.taglisten(tag_name, callback_function, all_events); function inside a .lp file?
I'm trying to do it and i'm getting this error from the browser:
Uncaught ReferenceError: grp is not defined
RE: javascript lp file - admin - 20.10.2022
grp.taglisten is only available in the visualization context. In apps/.lp files you can only listen to all group addresses. This only works for authorized users.
<!DOCTYPE html> <html lang="en"> <head>   <meta charset="UTF-8">   <title>Localbus</title>   <script src="/apps/js/jquery.js.gz"></script>   <script src="/scada/vis/busdecode.js.gz"></script>   <script src="/apps/js/localbus.js.gz"></script> </head> <body> <script> $(function() {   localbus.init();   localbus.listen('groupwrite', function(event) {     console.log(event.dst, event.value);   }); }); </script> </body> </html>
RE: javascript lp file - jmir - 20.10.2022
Ok.
I've seen that event has no tag neither name info, is there any way to get it inside .lp file?
This way you can filter events by a single tag:
<? require('apps') objs = grp.tag('TAGNAME') tagobjs = {} for _, obj in ipairs(objs) do   tagobjs[ #tagobjs + 1 ] = obj.address end ?> <!DOCTYPE html> <html lang="en"> <head>   <meta charset="UTF-8">   <title>Localbus</title>   <script src="/apps/js/jquery.js.gz"></script>   <script src="/scada/vis/busdecode.js.gz"></script>   <script src="/apps/js/localbus.js.gz"></script> </head> <body> <script> $(function() {   var tagobjs = <?=json.encode(tagobjs)?>;   localbus.init();   localbus.listen('groupwrite', function(event) {     if (tagobjs.indexOf(event.dst) >= 0) {       console.log(event.dst, event.value);     }   }); }); </script> </body> </html>
RE: javascript lp file - jmir - 21.10.2022
Thanks it works!
But is there any way to get group address values when loading the page? I'd like to get them when opening the page and not wait until one of them is sent to the bus.
RE: javascript lp file - admin - 21.10.2022
Try this:
<? require('apps') objs = grp.tag('TAGNAME') tagobjs = {} for _, obj in ipairs(objs) do   tagobjs[ #tagobjs + 1 ] = obj.address end ?> <!DOCTYPE html> <html lang="en"> <head>   <meta charset="UTF-8">   <title>Localbus</title>   <script src="/apps/js/jquery.js.gz"></script>   <script src="/scada/vis/busdecode.js.gz"></script>   <script src="/apps/js/localbus.js.gz"></script> </head> <body> <script> $(function() {   var tagobjs = <?=json.encode(tagobjs)?>;   function getvalue(addr) {     var id = localbus.encodega(addr);     return localbus.object[ id ];   }   $(localbus).on('connect', function() {     console.log('connected');     console.log(getvalue('0/0/1'));   });   localbus.init();   localbus.listen('groupwrite', function(event) {     if (tagobjs.indexOf(event.dst) >= 0) {       console.log(event.dst, event.value);     }   }); }); </script> </body> </html>
Perfect, thanks!
