Mosaic shortcuts - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Mosaic shortcuts (/showthread.php?tid=4308) |
Mosaic shortcuts - tpospichal - 21.10.2022 Is there any possibility, how to add widget on main page which will open another Mosaic page? Shortcuts? Thank you RE: Mosaic shortcuts - Daniel - 21.10.2022 Did you try using option 'Show navigation on Main page' ? You can add a icon to this buttons. RE: Mosaic shortcuts - tpospichal - 21.10.2022 (21.10.2022, 07:32)Daniel Wrote: Did you try using option 'Show navigation on Main page' ? You can add a icon to this buttons. Hi client wants to show function block container on main page for example Lights, climate etc.... RE: Mosaic shortcuts - Daniel - 21.10.2022 Sorry it is not clear what you need. RE: Mosaic shortcuts - tpospichal - 22.10.2022 (21.10.2022, 14:41)Daniel Wrote: Sorry it is not clear what you need.Widget/button, which open another webpage on click.... basically. RE: Mosaic shortcuts - Daniel - 24.10.2022 There is HTML widget where you can build it yourself in HTML but this will work only locally. RE: Mosaic shortcuts - tpospichal - 24.12.2022 (24.10.2022, 08:21)Daniel Wrote: There is HTML widget where you can build it yourself in HTML but this will work only locally. Can you pls give me any Example? My client wants to change little bit order of the mosaic structure. So i need to have possiblity to make widget which will open another page (room) in Mosaic structure. Thank you. |
