to View 2 Logic Machine in 1 Logic Machine Visualation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: to View 2 Logic Machine in 1 Logic Machine Visualation (/showthread.php?tid=4317) |
to View 2 Logic Machine in 1 Logic Machine Visualation - savaskorkmaz - 24.10.2022 Hi, I have 1 master and a second Logic Machine. ( Master is 192.168.1.81 and second is 192.168.1.82 ) Both Logic Machine have own visu. graphics pages. I need to see all visualization graphics in Master LM. I created a page in Master LM which includes a Frame. URL is in Frame http://username:Password1@192.168.1.82/scada-vis I checked Allow external access via iframe settings. It didn't worked. How can i see pages of second LM in a frame in Master LM ? Regards RE: to View 2 Logic Machine in 1 Logic Machine Visualation - Daniel - 24.10.2022 The browser most likely is blocking simple authentications. Disable (to test) visualization password in second LM. RE: to View 2 Logic Machine in 1 Logic Machine Visualation - khalil - 24.10.2022 Also, See this https://forum.logicmachine.net/showthread.php?tid=4058 RE: to View 2 Logic Machine in 1 Logic Machine Visualation - savaskorkmaz - 24.10.2022 (24.10.2022, 12:11)Daniel Wrote: The browser most likely is blocking simple authentications. Disable (to test) visualization password in second LM. Hi , It didnt worked. Also there is a security problem if i disable password for second LM. Is there a way to make this using any javascript method etc. Frame is not important RE: to View 2 Logic Machine in 1 Logic Machine Visualation - Daniel - 24.10.2022 If it didn't worked then you set something incorrectly. There is not really any work around for simple auth as it is browser who is blocking it. Your option is: 1. Accept that you will have to type user/password each time you login. 2. Add objects for visu from second LM and make single visu on one LM. |
