Old DALI package problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Old DALI package problem (/showthread.php?tid=4318) |
Old DALI package problem - Konstantin - 24.10.2022 Hi, I had the imprudence to upgrade my old LM2 (AT91) to the latest known 20181002 version. As it turned out, there was no DALI package in the OS image. Old AT91 DALI package (2015) doesn't works with this OS version. As well OS downgrade. So would you suggest any solution? Maybe there is more recent DALI package? Best regards, Konstantin RE: Old DALI package problem - admin - 25.10.2022 Unfortunately we don't have packages for old hardware anymore. RE: Old DALI package problem - Konstantin - 25.10.2022 In that case would you please tell me how to revert to an old OS version (downgrade)? BR, Konstantin RE: Old DALI package problem - admin - 25.10.2022 See attached doc. You will need a USB-UART (TTL) adapter for this. RE: Old DALI package problem - Konstantin - 25.10.2022 (25.10.2022, 11:47)admin Wrote: See attached doc. You will need a USB-UART (TTL) adapter for this. Thanks a lot! That's quite enough. BR, Konstantin Alas, I've got only complete OS images like lm2-at91.img or some old image like at91-oc8s.img. Where can I find kernel.img and data.img? BR, Konstantin RE: Old DALI package problem - Konstantin - 26.10.2022 What if I just reflash with lm2-at91.img from 0x0300000 NAND address? RE: Old DALI package problem - admin - 26.10.2022 This will most likely fail but you can try. |
