Mosaic Rotary Dimmer Icon - Printable Version
+--- Thread: Mosaic Rotary Dimmer Icon (/showthread.php?tid=4358)
Mosaic Rotary Dimmer Icon - Igor - 07.11.2022
Recently I noticed what rotary dimmer icon disappeared.
Before firmware update everything were fine, but after they started randomly disappear.
Now I do not see them whatever I do or change.
Maybe this is known bug, I did not found threads with similar problems...
Thank you.
RE: Mosaic Rotary Dimmer Icon - admin - 08.11.2022
Can you send your Mosaic backup via PM?
RE: Mosaic Rotary Dimmer Icon - admin - 09.11.2022
Thanks for the backup but I cannot reproduce this issue. Which browser/platform are you using? Can you try a different browser?
RE: Mosaic Rotary Dimmer Icon - Igor - 09.11.2022
I am using MacOS with Safari, but also I see same issue on iPhone(App or safari).
Tested with Chrome and everything works correctly...
Other iPhone works correctly(App)...
Tried to reset web pages data on iPhone did not helped, same with creating new user...
RE: Mosaic Rotary Dimmer Icon - Daniel - 10.11.2022
Maybe try to uninstall the app and install it again.
RE: Mosaic Rotary Dimmer Icon - admin - 10.11.2022
Mosaic update has been published. Please update and see if it works for you.
RE: Mosaic Rotary Dimmer Icon - Igor - 11.11.2022
Updated and now everything is working as it should. Magic... Smile
Thank you.
RE: Mosaic Rotary Dimmer Icon - YOUSSEF - 08.12.2022
Hello
i have a display problem with rotary dimmer mosaic, it is not taking the right state value , exp : i put value 50% ( 50% is sent on the KNX) and it will jump to 90%on mosaic ( not sent on the KNX bus)
i did already the last update
RE: Mosaic Rotary Dimmer Icon - Daniel - 08.12.2022
is the object scale or 1byte unsigned?
(08.12.2022, 13:31)Daniel Wrote: is the object scale or 1byte unsigned?
yes
yes
its scale
Did you change the maximum/minimum value in the settings?
RE: Mosaic Rotary Dimmer Icon - YOUSSEF - 09.12.2022
(08.12.2022, 16:34)Daniel Wrote: Did you change the maximum/minimum value in the settings?
I did change at first , and then put it back 0-100% , same nothing change.
RE: Mosaic Rotary Dimmer Icon - Daniel - 09.12.2022
Please double check that both control and status object have same dpt scale. I just played with it and it works just fine. Widget will show what is in status object so make sure correct value is there.
RE: Mosaic Rotary Dimmer Icon - davidchispas - 12.12.2022
Hello, I have noticed that since the previous mosaic update of October something happens with the rotating icon of percentage of blinds.
I have made the updates available and constantly updating the cloud. I can only reproduce this by accessing the cloud from a mobile device, in this case with an iPhone from Safari and Chrome. From a PC it does not play.
My steps to reproduce the problem are:
-1. Access mosaic from the cloud, the rotary icon appears but without the value in %.
-2. I lock the mobile device so that the screen turns off and unlock again. Now the percentage appears.
-3. When leaving the page and re-entering it, it disappears again.
RE: Mosaic Rotary Dimmer Icon - admin - 12.12.2022
Mosaic has been updated, see if it fixes the issue for you.
(12.12.2022, 12:19)admin Wrote: Mosaic has been updated, see if it fixes the issue for you.
Perfect! Thank you very much for the speed
