can't get floor heating lua script to work on wiser - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: can't get floor heating lua script to work on wiser (/showthread.php?tid=4373) |
can't get floor heating lua script to work on wiser - h5345 - 10.11.2022 hi, i got to this forum by googling and found a post about floor heating and virtual thermostat https://forum.logicmachine.net/showthread.php?tid=3572&pid=23068 i have 4 temp sensors (which show up correctly in the objects tab, data type is 09.001 2 bytes floating point) and a 6 way heating actuator (i can activate its channels by switching the channels value to true or false in the objects tab, data type is 01.002 boolean) i added the floor heating widget and configured it like the following https://imgur.com/a/RzpfwDe i added a resident script with a 60s cycle and activated it this is the script i came up with --on/off widget status statoonoff = grp.getvalue('32/1/4') --write temperature to variable tstudio = grp.getvalue('0/0/78') --write widget setpoint temp to variable settemp = grp.getvalue('32/1/3') --check if the widget is enabled if statoonoff==1 then --check if setpoint is lower or greater in that room if (settemp > tstudio) then -- if setpoint is greater switch actuator channel on grp.write('0/1/19', true) else --if setpoint is lower then switch actuactor channel off grp.write('0/1/19', false) end --if widget is set to off turn off heating else grp.write('0/1/19', false) end the script isnt working, does anyone know whats wrong with it? RE: can't get floor heating lua script to work on wiser - admin - 10.11.2022 32/1/4 is most likely boolean so this if does not work: Code: if (statoonoff == 1) thenIt should be compared with true/false not 1/0. It can also be simply written like this: Code: if statoonoff thenRE: can't get floor heating lua script to work on wiser - h5345 - 10.11.2022 (10.11.2022, 12:13)admin Wrote: 32/1/4 is most likely boolean so this if does not work: 32/1/4 was 01.001 data type, idk why it wasnt working. I changed it to 01.002 and used if statoonoff and its working, so thank you!! |
