User login "log" - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: User login "log" (/showthread.php?tid=4385) |
User login "log" - DGrandes - 16.11.2022 Hi, Is there any way to get user name and external IP when someone access to Logic Machine? I need to register that. Thanks! RE: User login "log" - admin - 16.11.2022 User access > Access logs RE: User login "log" - DGrandes - 16.11.2022 (16.11.2022, 09:05)admin Wrote: User access > Access logs Ok thanks! Buy I need to "Alert" when this happens. How can I get that with lua event script or Javascript? I need to send by telegram, email... Thanks! RE: User login "log" - DGrandes - 02.12.2022 (16.11.2022, 09:23)DGrandes Wrote:(16.11.2022, 09:05)admin Wrote: User access > Access logs Sorry, is not possible get connected user when event script run? RE: User login "log" - admin - 02.12.2022 Possible: https://forum.logicmachine.net/showthread.php?tid=3119&pid=20192#pid20192 RE: User login "log" - DGrandes - 02.12.2022 (02.12.2022, 10:47)admin Wrote: Possible: https://forum.logicmachine.net/showthread.php?tid=3119&pid=20192#pid20192 Ok thanks so much! Another question. Is there any way to get internal IP of connected device? RE: User login "log" - admin - 02.12.2022 Not at the moment, but in the new firmware the meta field will have USER:IP format. RE: User login "log" - DGrandes - 02.12.2022 (02.12.2022, 11:32)admin Wrote: Not at the moment, but in the new firmware the meta field will have USER:IP format. Ok thanks |
