Can not sync LogicMachine created GA objects - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Can not sync LogicMachine created GA objects (/showthread.php?tid=4406) |
Can not sync LogicMachine created GA objects - tigi - 28.11.2022 Hi, I'm having trouble with group addresses created on the logicmachine, when doing a GroupValueRead request from HomeAssistant. I only encounter this with group addresses (not virtual) I made in the LM. When a value changes by the LM itself the data is correctly send on the bus and updated in HA, but reading them doesn't work. When I look into the objects logs I see that read requests are coming in but the decoded value, data type, object data are empty. The source address 1.1.3 is the one from the HA. When looking at the logs in HA I get 'knx bus did not respond in time' but as said only for the GroupAddresses which are created in the LM Is this normal behaviour or is there something I need to change on the LM to get this working? Thanks! RE: Can not sync LogicMachine created GA objects - admin - 28.11.2022 See this: https://forum.logicmachine.net/showthread.php?tid=332&pid=1600#pid1600 RE: Can not sync LogicMachine created GA objects - tigi - 28.11.2022 (28.11.2022, 12:05)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=332&pid=1600#pid1600 Hi admin, Thanks for saving the day ![]() The fun part is, I already found that post but apparently read it to fast and not thoroughly... I overlooked the essential part 'and turn on the execute read checkbox just once for this single script' Thanks for bringing that post under my attention again! |
