Changing BRN1407 secondary card on LM3 ? - Printable Version
+--- Thread: Changing BRN1407 secondary card on LM3 ? (/showthread.php?tid=4411)
Changing BRN1407 secondary card on LM3 ? - olivier - 30.11.2022
Hi all,
My LM3 stop working last week
(it used to working like a charm)
There is secondary card plugged on the main board,
with the reference BRN1407 on it, it hosts the microprocessor and the SDcard
So, is it possible to just buy & change this secondary card ?
Best regards
Olivier
RE: Changing BRN1407 secondary card on LM3 ? - Daniel - 30.11.2022
Yes fallow this guide https://openrb.com/reflash-logicmachine3-and-streaming-player-software/
Use imx28 recovery image.
RE: Changing BRN1407 secondary card on LM3 ? - olivier - 30.11.2022
hi Daniel
thank you for your response, I will try to reflash the SD
maybe it will solve the issue Smile
My question was more : in case of hardware issue, is it possible to just exchange the secondary card with a new one ?
Best regards
Olivier
RE: Changing BRN1407 secondary card on LM3 ? - admin - 30.11.2022
These boards are not produced anymore. We might have some old ones used for testing but most likely you will have to replace the whole device with LM5.
ok, thank you for your response
