Modbus TCP/IP: read_swap not work - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus TCP/IP: read_swap not work (/showthread.php?tid=4414) |
Modbus TCP/IP: read_swap not work - Domoticatorino - 30.11.2022 Hi, here enclosed register map of a device. What is wrong with json profile below? {"name":"Heating Energy kWh","bus_datatype":"int32","datatype":"int32","type":"register","address":71,"read_swap":"w"} I mean the I read the same value declaring "read_swap":"w" or not declaring it. Where is my fault please? Thanks. BR RE: Modbus TCP/IP: read_swap not work - admin - 01.12.2022 "w" is the default swap mode. Try using "n" instead. RE: Modbus TCP/IP: read_swap not work - Domoticatorino - 03.12.2022 (01.12.2022, 07:12)admin Wrote: "w" is the default swap mode. Try using "n" instead. Thank you Admin!! |
