W4KNX, position of Sun (time) - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: W4KNX, position of Sun (time) (/showthread.php?tid=4427) |
W4KNX, position of Sun (time) - eurosting - 06.12.2022 Hello all, I'm the new one and I'm using the W4KNX device as KNX gateway for ETS software only. I don't have any weather station at the moment, but need to switch ON/OF the door lights in the late evening and early morning. I found the fbeditor on the W4KNX device and tried to use block "position of Sun (time)". This blocks provides sunset and sunrise times, which I could use. Unfortunately the time is in decimal format (example 7:30min -> 7:50) , and this time has data type 14 byte ASCII string (orther types don't provide any values). How to get sunrise time and sunset time as "normal 3 byte time" ? And second question about this script: Change the Scheduled program time parameters dynamically from visualization I add this user function in to user function library. As soon as this script is running I see following errors: Resident script:1: attempt to call global 'scheduler' (a nil value) stack traceback: Lss100100 firmware v2.70 Please advise. Best regards. RE: W4KNX, position of Sun (time) - CristianAgata - 06.12.2022 (06.12.2022, 19:59)eurosting Wrote: Hello all,Hi, Use a simple schedule and add event on at the sun down and a off event on the sun rise. You can adjust the event time. Remember to set up time, date and your position. Best regards Cristian RE: W4KNX, position of Sun (time) - eurosting - 07.12.2022 (06.12.2022, 20:58)CristianAgata Wrote: Hi, Hi, the schedule offers only to set the day (of vacation), there is no setting for time or sunset. RE: W4KNX, position of Sun (time) - CristianAgata - 07.12.2022 (07.12.2022, 20:17)eurosting Wrote:(06.12.2022, 20:58)CristianAgata Wrote: Hi, Hi, this is the app, or better in LM it is..... In the setting is there the folder scheduled? I can set in this part. Let me know. BR Cristian RE: W4KNX, position of Sun (time) - eurosting - 07.12.2022 Thanks, I found this setting now. I need to create a schedule first, then I get new options to set events. |
