BacNetIP - issues - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: BacNetIP - issues (/showthread.php?tid=4439) |
BacNetIP - issues - Re-G - 12.12.2022 Hi. I have problem witch BacNet IP client (app). We have to integrate an AHU made by Svegon (GOLD). Application found a device but if i start looking for data points i have as a result those scenario:
I tried:
I tried web browsers: Chrome, Firefox, Safari. I tried on LM firmware 2022 RC1, 2022 RC1 and with this one https://dl.openrb.com/lm-22-imx6/lm5m3ex-20221205.img also witch 20211215. Any ideas what's going on? Thanks for help. RE: BacNetIP - issues - Daniel - 12.12.2022 This app has its known limitation. It works on very small installations. You better try our original solution https://openrb.com/logicmachine-as-bacnet-client/ Uninstall the app if you going to use this. RE: BacNetIP - issues - Re-G - 12.12.2022 (12.12.2022, 09:44)Daniel Wrote: This app has its known limitation. It works on very small installations. You better try our original solution Thanks for quick answer. But i can't. This is LM5 Lite. RE: BacNetIP - issues - Daniel - 12.12.2022 Install the genohm-scada-bacnet.ipk from Extra packages in: Sys Config –> System –> Packages If you use RC1 22 then take packages from here https://dl.openrb.com/lm-22-imx6/pkg/ RE: BacNetIP - issues - Re-G - 12.12.2022 (12.12.2022, 09:59)Daniel Wrote: Install the genohm-scada-bacnet.ipk from Extra packages in: Sys Config –> System –> Packages Thanks. I did it. Scaning is working well. could you be so polite and tell me how add Bagnet data points to objects? Thanks again. RE: BacNetIP - issues - Daniel - 12.12.2022 You have to use script for this, there are examples in the link I sent you. RE: BacNetIP - issues - Re-G - 12.12.2022 (12.12.2022, 10:16)Daniel Wrote: You have to use script for this, there are examples in the link I sent you.Thanks. |
