Match nth item of a string - Printable Version
+--- Thread: Match nth item of a string (/showthread.php?tid=4455)
Match nth item of a string - Joep - 18.12.2022
I'm looking for a way to grab the value of the 3th parent and 2th child item of a string. Below an example of the data i get. The value i need is marked in red. It's not possible to use the id's as they change all the time. With css it's done like this item:nth-child(3) item:nth-child(2) but how is it done in Lua?
<values>
  <item id='0x8764bc'>
      <item id='0x87676c'>
        <value>32.5°C</value>
      </item>
      <item id='0x87de1c'>
        <value>28.6°C</value>
      </item>
      <item id='0x87de64'>
        <value>28.4°C</value>
      </item>
      <item id='0x876724'>
        <value>62.7°C</value>
      </item>
  </item>
  <item id='0x876504'>
      <item id='0x8b7ab4'>
        <value>Aan</value>
      </item>
      <item id='0x87e0d4'>
        <value>Aan</value>
      </item>
  </item>
  <item id='0x8765dc'>
      <item id='0x878554'>
        <value>Uit</value>
      </item>
      <item id='0x861b84'>
        <value>Aan</value>
      </item>
      <item id='0x861bcc'>
        <value>Aan</value>
      </item>
      <item id='0x87850c'>
        <value>Aan</value>
      </item>
  </item>
</values>
RE: Match nth item of a string - admin - 20.12.2022
It makes more sense to find values by ID instead of position inside of the XML that can potentially change. Try this:
data = [[ <values>   <item id='0x8764bc'>       <item id='0x87676c'>         <value>32.5°C</value>       </item>       <item id='0x87de1c'>         <value>28.6°C</value>       </item>       <item id='0x87de64'>         <value>28.4°C</value>       </item>       <item id='0x876724'>         <value>62.7°C</value>       </item>   </item>   <item id='0x876504'>       <item id='0x8b7ab4'>         <value>Aan</value>       </item>       <item id='0x87e0d4'>         <value>Aan</value>       </item>   </item>   <item id='0x8765dc'>       <item id='0x878554'>         <value>Uit</value>       </item>       <item id='0x861b84'>         <value>Aan</value>       </item>       <item id='0x861bcc'>         <value>Aan</value>       </item>       <item id='0x87850c'>         <value>Aan</value>       </item>   </item> </values>]] function starttag(p, tag, attrs)   if tag == 'item' then     id = attrs.id   elseif tag == 'value' then     value = true   end end function endtag(p, tag)   if tag == 'item' then     id = nil   elseif tag == 'value' then     value = nil   end end function text(p, tdata)   if value and id then     values[ id ] = tdata     value = nil   end end values = {} require('lxp').new({   StartElement = starttag,   EndElement = endtag,   CharacterData = text, }):parse(data) log(values)
RE: Match nth item of a string - Joep - 20.12.2022
With this function i got a nice result of the items with their values but as the ID's change with every new connection made i can't use them.
Also the sorting is different using this function and with the raw data it's not. Below to examples with different ID's as you can see.
* table:
["0xe9fd3c"]
* string: 3144h
["0xe9a164"]
* string: 0.01 V
["0xde6bb4"]
* string: Aan
["0xe5a494"]
* string: Verwarmen
* table:
["0xee5dc4"]
* string: 3144h
["0xeb74cc"]
* string: 31 Hz
["0xebf184"]
* string: 1070
["0xf1a3f4"]
* string: 17593.1 kWh
This one is solved by Erwin van der Zwart already. He send me this solution that create a table with sorted numbering.
table.insert(values, tdata)
    value = nil
