TCP over SSL - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: TCP over SSL (/showthread.php?tid=446) |
TCP over SSL - oyvindi - 31.10.2016 Hi, anybody had any success creating an SSL server listener in LUA ? There seems to be an issue with the server socket not being able to receive() from the client. Sending from server to client however, works just fine. Note that I tried using it in a copas handler first, and then as a simple standalone luasec handler (running on my machine, not in LM) Simple test code looks like this: Code: local socket = require("socket")
local ssl = require("ssl")
local params = {
mode = "server",
protocol = "tlsv1_2",
key = "C:\\ .... \\serverkey.pem",
certificate = "C:\\ .... \\server.pem",
cafile = "C:\\ .... \\root.pem",
verify = {"peer", "fail_if_no_peer_cert"},
options = "all",
local server = socket.tcp()
local ctx = assert(ssl.newcontext(params))
server:setoption('reuseaddr', true)
assert( server:bind("10.20.2.92", 2000) )
server:listen()
local peer = server:accept()
peer = assert( ssl.wrap(peer, ctx) )
peer:dohandshake()
data = peer:receive() -- <--- HANGS !
print("receieved: " .. data)
peer:send("Pong!\n")
peer:close()RE: TCP over SSL - admin - 01.11.2016 SSL server is not yet supported, we'll try to prepare an update this week though
RE: TCP over SSL - oyvindi - 01.11.2016 (01.11.2016, 09:30)admin Wrote: SSL server is not yet supported, we'll try to prepare an update this week though Ok ! I assume it will be via luasec ? I got my code working though, turned out to be a hickup on the client side. RE: TCP over SSL - rocfusion - 16.10.2017 Hi Admin, Is there any update on running an ssl server on the lm? Can this be done without a cert? Thanks, Roger RE: TCP over SSL - admin - 16.10.2017 It's possible, but you cannot run it without a certificate. You can reuse web-server's self-signed certificate though. Here's a short example: Code: if not tcpserver then
require('copas')
sslparams = {
mode = 'server',
protocol = 'tlsv12',
key = '/etc/nginx_sha256.key',
certificate = '/etc/nginx_sha256.crt',
options = 'all',
-- connection handler
function connhandler(sock)
local ip, port = sock:getpeername()
sock = copas.wrap(sock, sslparams)
sock:dohandshake()
alert('[server] connection from %s:%d', ip, port)
-- main reader loop
while true do
-- wait for single line of data (until \n, \r is ignored)
local data, err = copas.receive(sock, '*l')
-- error while receiving
if err then
alert('[server] closed connection from %s:%d', ip, port)
return
-- handle data frame
if data == 'HELLO' then
sock:send('HELLO TO YOU\r\n')
sock:close()
-- bind to port 12345
tcpserver = socket.bind('*', 12345)
-- error while binding, try again later
os.sleep(5)
error('[server] error: cannot bind')
-- set server connection handler
copas.addserver(tcpserver, connhandler)
copas.step(1)RE: TCP over SSL - rocfusion - 18.10.2017 Thanks Admin, that works.. RE: TCP over SSL - rocfusion - 19.10.2017 Hi Admin, A couple of questions, Will this server support multiple clients? I added a basic authentication, that just sets a global variable on connecting and closes the connection if the password is incorrect. The data received is passed another function parseC. Now I need to be able to respond back to the connected client where I declared a global function in this handler. Is this the right way to do this? Code: -- handle data frame
if data then
if(first==true)then
if(data ~='mypassword')then
first=false
sock:close()
Sclient= function (param)
sock:send(param)
local fd,prtd = pcall(parseC,data)
if(fd==false)then
alert("[elk-client] Error with parsemsg %s ",prtd)
endThanks, Roger RE: TCP over SSL - admin - 19.10.2017 Yes, it supports multiple clients. See this example on how to pass data to all connected clients: http://openrb.com/example-lm2-as-tcp-server-for-external-requests/ You can pass any number of arguments via pcall, you can pass both data and socket if you want to send a reply to a specific client. |
