Thermostat Script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Thermostat Script (/showthread.php?tid=4471) |
Thermostat Script - mishoboss - 28.12.2022 Hi folks, can anyone suggest (or kindly give a snippet) how to create a simple thermostat script? The idea is to have 3 GA - current temperature, setpoint temperature and control valve (1 bit output). And turn on/off the output control valve depending on the current temperature and setpoint values with a given hysteresis (e.g. 1 degree). RE: Thermostat Script - AEK - 29.12.2022 (28.12.2022, 22:52)mishoboss Wrote: Hi folks, can anyone suggest (or kindly give a snippet) how to create a simple thermostat script? create event based script, map it on tag "thermostat1", map the same tag to current and setpoint objects. paste code to script (change GA addresses to what you need) cur = grp.getvalue('current temp address or name') set= grp.getvalue('setpoint temp address or name') if set > cur then grp.write('valve address or name', true) else grp.write( 'valve address or name', false) end |
