Change Duplex settings through scripts - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Change Duplex settings through scripts (/showthread.php?tid=4481) |
Change Duplex settings through scripts - robikozo - 07.01.2023 Hello, is it possible to change this setting through scripting? RE: Change Duplex settings through scripts - admin - 09.01.2023 Can you explain why do you need to change it? For RS485 duplex must be set to half. It won't work with full duplex. RE: Change Duplex settings through scripts - robikozo - 09.01.2023 (09.01.2023, 07:48)admin Wrote: Can you explain why do you need to change it? For RS485 duplex must be set to half. It won't work with full duplex. I have a smart RS485 energy meter 'Inepro MOD380' After every time the grid turns off LM5 doesnt see the signal, then if i change to full-duplex and then back to half-duplex it suddenly works again, it is the only way it reconnects to the meter. That is why RE: Change Duplex settings through scripts - admin - 10.01.2023 You can restart Modbus via a script like this: Code: os.execute('sh /lib/genohm-scada/plugins/modbus/stop.sh')
os.sleep(1)
os.execute('sh /lib/genohm-scada/plugins/modbus/start.sh')RE: Change Duplex settings through scripts - Snog - 01.07.2025 (09.01.2023, 18:22)Robikozo Wrote:(09.01.2023, 07:48)Hello, Wrote: Do you have the Modbus profile? |
