Mosaic Widget - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Mosaic Widget (/showthread.php?tid=4482) |
Mosaic Widget - 2MAX - 09.01.2023 Hi, is it possible to do scene selector with feedback of highlighted button in mosaic visualisation? Something like attached image? RE: Mosaic Widget - Daniel - 09.01.2023 Right now there is no direct way to do it, widget objects have only a bit status. Our scenes can be triggered from a bit object but how do you know if a scene is still active? You could monitor all status objects and update it via a script. RE: Mosaic Widget - 2MAX - 09.01.2023 (09.01.2023, 13:43)Daniel Wrote: Right now there is no direct way to do it, widget objects have only a bit status. Our scenes can be triggered from a bit object but how do you know if a scene is still active? You could monitor all status objects and update it via a script. I´m using scene to select which adress is send to the bus on event and the feedback in visu would be fine. select=grp.getvalue("32/1/3") if (select == 0) then elseif (select == 1) then grp.write("1/0/1", event.getvalue()) elseif (select == 2) then grp.write("1/0/2", event.getvalue()) elseif (select == 3) then grp.write("1/0/1", event.getvalue()) grp.write("1/0/2", event.getvalue()) end RE: Mosaic Widget - Daniel - 09.01.2023 You can make 3 bit objects and on press of one to true you trigger your first scene and write false to other two. Do the same with all three. 3 event scripts and you done. |
