GA comment with JSON - Printable Version
+--- Thread: GA comment with JSON (/showthread.php?tid=4490)
GA comment with JSON - tomnord - 12.01.2023
Is it possible to add comments for objects in the Json profile? e.g:
{       "address": 8,       "bus_datatype": "bool",       "bus_address":"32/1/16",       "name": "Status",       "comment": "Status of input",       "type": "discreteinput",     },
RE: GA comment with JSON - admin - 12.01.2023
No, because bus_address does not create new objects. It only works with existing objects.
RE: GA comment with JSON - tomnord - 12.01.2023
(12.01.2023, 08:14)admin Wrote: No, because bus_address does not create new objects. It only works with existing objects.
but "units": work.. Is this not the same thing?
Ok, so you want the comment field to be filled from the profile when mapping new objects. This is not possible at the moment.
