Programming devices via ZeroTier - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Programming devices via ZeroTier (/showthread.php?tid=4506) Pages:
Programming devices via ZeroTier - Ceros2112 - 18.01.2023 Hello, I have an installation with one LM5 and three Ip router, with ZeroTier I can reach LM5 via ETS but I can't program devices. In diagnostic I can't reach any of the devices via individual address but if I scan the line I can definitely see them and bus monitor works. I know that probably is something simple but I can't figure out what the problem is, any ideas? Thanks RE: Programming devices via ZeroTier - Daniel - 18.01.2023 You can only program devices directly connected to LM. RE: Programming devices via ZeroTier - Ceros2112 - 18.01.2023 Is there any way to use LM5 as a gateway to reach ip routers? RE: Programming devices via ZeroTier - Daniel - 18.01.2023 If you change temporarily LM knx mode to tunneling and set connection to your IP router it might actually work. Never tested
RE: Programming devices via ZeroTier - Ceros2112 - 18.01.2023 Nope, if I set lm5 to tunnelling I can't even reach it via ETS. I'll do some other tests though. RE: Programming devices via ZeroTier - Daniel - 18.01.2023 Check PM and let me know if it works. RE: Programming devices via ZeroTier - Admirim Toska - 22.01.2023 Hello all I have the same problem... i was programming devices ok until Wednesday 18.01.2023 but now i can not program KNX devices that are connected directly to LM. Logic machine is online, i can reach it and ETS show Connection on ... only i can not program devices or control group addresses. Thank you for your help Admirim RE: Programming devices via ZeroTier - admin - 23.01.2023 Check that LM KNX connection mode is set to TP-UART. RE: Programming devices via ZeroTier - Admirim Toska - 24.01.2023 Yes, LM KNX connection is set to TP-UART and i was programing devices for 2 days... until Wednesday 18.01.2023 RE: Programming devices via ZeroTier - Daniel - 24.01.2023 Your problem is totally different then the one mentioned above. Check what has changed in your installation since 18.01 RE: Programming devices via ZeroTier - batistacaceres - 24.10.2023 (18.01.2023, 10:07)Ceros2112 Wrote: Nope, if I set lm5 to tunnelling I can't even reach it via ETS. I'll do some other tests though. Have you solve it, I have the same problem. How can I access to program knx devices below IProuters? When I access to knx network using zerotier, and my logicMachine is configured with address (1.1.0), as line acopler. Now I can only program knx devices located in line 1.1.x, but I can not access knx devices below IPRouter (1.2.0), even when they are in the same network switch. I have tried, like you do, LM5 to tunnelling, but I can not reach via ETS. Have you solve the problem? best regards Roger (18.01.2023, 10:11)Daniel Wrote: Check PM and let me know if it works. Hello: What´s PM? Have you solve it?, I have the same problem. How can I access to program knx devices below IProuters? When I access to knx network using zerotier, and my logicMachine is configured with address (1.1.0), as line acopler. Now I can only program knx devices located in line 1.1.x, but I can not access knx devices below IPRouter (1.2.0), even when they are in the same network switch. I have tried, like you do, LM5 to tunnelling, but I can not reach via ETS. Have you solve the problem? best regards Roger (18.01.2023, 10:11)Daniel Wrote: Check PM and let me know if it works. Hello: What´s PM? Have you solve it?, I have the same problem. How can I access to program knx devices below IProuters? When I access to knx network using zerotier, and my logicMachine is configured with address (1.1.0), as line acopler. Now I can only program knx devices located in line 1.1.x, but I can not access knx devices below IPRouter (1.2.0), even when they are in the same network switch. I have tried, like you do, LM5 to tunnelling, but I can not reach via ETS. Have you solve the problem? best regards Roger RE: Programming devices via ZeroTier - domotiqa - 24.10.2023 I d like to know also, can you share the info not even in PM? RE: Programming devices via ZeroTier - Daniel - 24.10.2023 Upcoming firmware will have this option as standard, please be patient a bit RE: Programming devices via ZeroTier - balatis - 25.10.2023 Hello from Greece, Because of our many projects that they need this solution, could we have a trial too? Thank you in advance. RE: Programming devices via ZeroTier - batistacaceres - 30.10.2023 (24.10.2023, 15:31)domotiqa Wrote: I d like to know also, can you share the info not even in PM? Please, Could you tell me what PM means? thank you, best regards Roger RE: Programming devices via ZeroTier - Zen - 31.10.2023 (30.10.2023, 10:08)batistacaceres Wrote:(24.10.2023, 15:31)domotiqa Wrote: I d like to know also, can you share the info not even in PM? PM = Private Message Someone calls it DM - Direct Message RE: Programming devices via ZeroTier - AEK - 06.11.2023 (24.10.2023, 15:39)Daniel Wrote: Upcoming firmware will have this option as standard, please be patient a bit Hi Daniel. correct me if I'm wrong. I have LM with line 1.1.x and 2 IP routers with line 1.2.x. and 1.3.x right now i can't program line 1.2.x due to security reasons while i'm connected to LM (but can, if I connected to router of line 1.3.x) with new firmware i will can set KNX connection mode in LM to Tunneling and set the IP of router 1.2.x and then it would be possible to programm devices in line 1.2.x, while I'm connected to LM? RE: Programming devices via ZeroTier - Daniel - 06.11.2023 (06.11.2023, 12:56)AEK Wrote:(24.10.2023, 15:39)Daniel Wrote: Upcoming firmware will have this option as standard, please be patient a bit Correct RE: Programming devices via ZeroTier - AEK - 06.02.2024 (06.11.2023, 13:07)Daniel Wrote:(06.11.2023, 12:56)AEK Wrote:(24.10.2023, 15:39)Daniel Wrote: Upcoming firmware will have this option as standard, please be patient a bit Hi, Daniel! new firmware is released, is this feature implemented? RE: Programming devices via ZeroTier - Daniel - 06.02.2024 Yes, see in KNX settings: Pass ind. telegrams via IP Routing |
