Logic Machine Forum
Programming devices via ZeroTier - Printable Version
+--- Thread: Programming devices via ZeroTier (/showthread.php?tid=4506)
Pages: 1 2
RE: Programming devices via ZeroTier - Novodk - 11.04.2024
(06.02.2024, 11:30)Daniel Wrote: Yes, see in KNX settings:  Pass ind. telegrams via IP Routing
Just to be sure If I have multiple IP Routers connected to the same VLAN
Router1: 1.1.0
Router2: 1.2.0
Router3: 1.3.0
Router4: 1.4.0
Router5: 1.5.0
And I Connect a LM to the same VLAN and set it to these settings and connect to it via ZeroTier, then i should be able to program all lines via ETS?[Image: 2MmzgBT.png]
RE: Programming devices via ZeroTier - admin - 12.04.2024
Yes, this should work with the latest firmware and "Pass ind. telegrams via IP Routing" enabled.
