Object write with - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Object write with (/showthread.php?tid=4515) |
Object write with - 2MAX - 19.01.2023 Hi, can You help me, the red part of script doesnt work to me. I need if STAV==1, to wait 5times x 10sec if it change to 0. STAV=grp.getvalue("10/1/181") pocet=5 if (event.getvalue()==true) then if(STAV==0) then grp.write("10/0/0", true) end else repeat os.sleep(10) pocet=pocet-1 if(STAV==0) then grp.write("10/0/0", true) end until (pocet==0) end RE: Object write with - tigi - 19.01.2023 I think the script will not work because of your 2nd IF statement and the declaration of STAV at the beginning. if STAV = 0 then do something, but if STAV is not zero do something ELSE. Then in that ELSE statement you check in your REPEAT loop if STAV is 0 again, but you ended there because STAV was something else than zero and you don't re-poll the STAV value, so you'll never meet that condition. I guess... RE: Object write with - 2MAX - 20.01.2023 (19.01.2023, 20:07)tigi Wrote: I think the script will not work because of your 2nd IF statement and the declaration of STAV at the beginning. I think so this is problem with update object, but how to do update of STAV during repeat? RE: Object write with - admin - 20.01.2023 You need to add another grp.getvalue call before checking the value. |
