Sending notifications with SIGNL4 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Sending notifications with SIGNL4 (/showthread.php?tid=4522) |
Sending notifications with SIGNL4 - CarlS - 23.01.2023 SignL4 is a mobile alerting system. They have a API, and have some examples at their homepage Is it possible to use one of these snippets below to send notification from LM5? The reason why I want to use this system is that I need a constant alert/sound/vibration on the phone until the user responds to the alarm https://www.signl4.com/inbound-webhook-code-snippets/ RE: Sending notifications with SIGNL4 - admin - 23.01.2023 Try this. Result and/or errors can be seen in the Logs tab. Code: secret = '12345'
title = 'alert'
message = 'alert from LM'
http = require('socket.http')
json = require('json')
ltn12 = require('ltn12')
data = json.encode({
Title = title,
Message = message,
resp = {}
res, code = http.request({
url = 'https://connect.signl4.com/webhook/' .. secret,
method = 'POST',
headers = {
['content-length'] = #data,
source = ltn12.source.string(data),
sink = ltn12.sink.table(resp),
if res and code == 200 then
resp = table.concat(tbl)
log(resp)
log(res, code)
endRE: Sending notifications with SIGNL4 - CarlS - 23.01.2023 (23.01.2023, 11:37)admin Wrote: Try this. Result and/or errors can be seen in the Logs tab. I get res = 1 and code = 404 resp: "code": 3004, "requestId": "b33c1f40-ecb1-4b4c-9a83-a4d15e1e2e8c", "details": "No matching event source found.", "message": "Error raising event." When I pase the url+secret in chrome i get this message: This XML file does not appear to have any style information associated with it. The document tree is shown below. <ErrorResponseContentBase xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Details>You need to POST JSON content to your webhook URL. Find more information at: https://www.signl4.com/developers/webhook/inbound/</Details> <Message>GET not supported.</Message> </ErrorResponseContentBase> RE: Sending notifications with SIGNL4 - admin - 23.01.2023 The Lua code is more or less the same as other examples. Maybe some other fields have to be added to the JSON request. Contact SIGNL4 support. |
