Faulty display of the gauges after a while - Printable Version
+--- Thread: Faulty display of the gauges after a while (/showthread.php?tid=4532)
Faulty display of the gauges after a while - Habib - 25.01.2023
For several firmware versions I have had the problem that my visualisation displays the meters incorrectly.
I have attached screenshots of the normal and the faulty display. This is always the same in different devices and browsers. A quarter of the counter is then displayed mirror-inverted... The longer you wait, the more counters are displayed incorrectly.
I also thought that they overlapped each other, but that wasn't the cause.
I currently have the latest 2023 RC1 Formware on it, but I already had this error on my Schneider spaceLYnk 1.0 when the meter display was changed.
RE: Faulty display of the gauges after a while - admin - 25.01.2023
What platform does your visualization display use?
RE: Faulty display of the gauges after a while - Habib - 25.01.2023
I use a Mac, my display is an Android 6 or so....
But I think I've also seen this on Windows...
I've tested it now under Windows 10 Pro with Firefox... it's the same as in MacOS
RE: Faulty display of the gauges after a while - Daniel - 25.01.2023
Can you send your backup to PM?
you have an PM :-)
Have you seen it in any other browser than Firefox?
(25.01.2023, 12:20)Daniel Wrote: Have you seen it in any other browser than Firefox?
Yes, I tried it in the past in Safari and chrome... but I will test it again... I will report
We can see it only in Firefox
I haven't actually been able to find an error in Chrome and Safari yet, so it does seem to be limited to Firefox. However, I will continue to monitor it.
Update: I have now tested it all afternoon and the error only occurred with Firefox. I think that makes it clear that this is a Firefox issue... Can you do something about it, e.g. via a work-a-round?
RE: Faulty display of the gauges after a while - admin - 26.01.2023
This will be fixed in the next firmware.
RE: Faulty display of the gauges after a while - Dré - 30.01.2023
(26.01.2023, 06:05)admin Wrote: This will be fixed in the next firmware.
Great, I have the same problem too.
@W10 with Firefox
