USB Drive - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: USB Drive (/showthread.php?tid=4533) |
USB Drive - dave.bolas@se.com - 25.01.2023 Hi, is there any way of programmatically reading the status of a USB drive ie, is it healthy and read to write? I had a corrupted drive and no obvious way of knowing until things stopped working. Thanks Dave RE: USB Drive - admin - 26.01.2023 There's no way of knowing if the USB drive is fully operational or not. You can only check if it is mounted or not: Code: mounted = io.readfile('/proc/mounts'):match('/dev/sd') ~= nil
log(mounted) |
