Alexa Room Temperature - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Alexa Room Temperature (/showthread.php?tid=4551) |
Alexa Room Temperature - vmic - 02.02.2023 Hi! I am having an issue regarding room temperature from KNX and announsing from Alexa. I am asking from Alexa Command to tell me the temperature of a room that is I am getting it from an ABB room display ( The object is a 2bytes , 9.001 temperature in Celcius ). When I ask from Alexa to tell me the room's temperature I am always getting the answer that the temperature is zero degrees. Also the Room Touch from ABB doen't have anything in Parameters to send the status temperature always for example every 2 seconds Why is that happening? RE: Alexa Room Temperature - CristianAgata - 02.02.2023 (02.02.2023, 17:01)vmic Wrote: Hi!Hi, For read cyclical the temperature, you can write a resident script ( every 50 sec for example) or a schedule script like this: Temp = grp.getvalue(your group) grp.checkupdate('virtual group',Temp,your delta) About Alexa I think you must check Alexa app config RE: Alexa Room Temperature - Daniel - 02.02.2023 Alexa only is checking object value in LM, as long it is updated then this Alexa will see. It does not ask RTC for latest value. RTC must update LM on its own. RE: Alexa Room Temperature - vmic - 03.02.2023 (02.02.2023, 17:14)CristianAgata Wrote:Hi! And thank you for your answer.(02.02.2023, 17:01)vmic Wrote: Hi!Hi, Beacuse I am not familiar with scripting stuff I tried to insert the above script in schedule script but I don't know how to do it. Is it possible to help me with more instructions please? I mean I have to create a new Group address inside ETS for getting the status or not (for the virtual group)? What are the steps to do that? RE: Alexa Room Temperature - admin - 03.02.2023 In object properties you can set poll interval to periodically send read requests to it. Script is not needed. RE: Alexa Room Temperature - vmic - 03.02.2023 (03.02.2023, 06:11)admin Wrote: In object properties you can set poll interval to periodically send read requests to it. Script is not needed.Yes now it works great! Thank you very much! |
