modbus - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: modbus (/showthread.php?tid=4564) |
modbus - Daponte - 07.02.2023 Hello, when installing the latest version of firmware (2023 RC1) the modbus RTU3 communication port has stopped communicating and when I try to enable it, it automatically deactivates it, with which I have lost communication with a meter through the RS-485 port, how can I solve it? RE: modbus - admin - 07.02.2023 You've probably installed wrong firmware. What hardware model is reported in System config > System > Upgrade firmware? RE: modbus - Daponte - 07.02.2023 (07.02.2023, 10:21)administración Wrote: Probablemente haya instalado un firmware incorrecto. ¿Qué modelo de hardware se informa en Configuración del sistema > Sistema > Actualizar firmware? RE: modbus - admin - 07.02.2023 You need to install LM5 Lite + Ext (4 or 6 DIN units) RE: modbus - Daponte - 07.02.2023 (07.02.2023, 10:28)admin Wrote: You need to install LM5 Lite + Ext (4 or 6 DIN units) I have reinstalled firmware + signature, and I have tried and it does the same thing, RTU1 and RTU2, perfect, RTU3 should not be enabled RTU3 does not allow enable, is there a way to do it? |
