Short - Long press - Printable Version
+--- Thread: Short - Long press (/showthread.php?tid=4575)
Short - Long press - Joep - 09.02.2023
Here's a simple script that calculate the time difference between 1 (true) and 0 (false) of a 1 bit object.
I have extended it with some examples on how to use it to calculate the ON time of an object and as a working hour timer.
long = 10 --set long press in seconds value = event.getvalue() object = grp.find(event.dst) if value then   if not storage.get('start') then     storage.set('start', object.updatetime)   end else   start = storage.get('start')   if start then       diff = os.difftime(object.updatetime, start)   end   storage.delete('start') end if diff then   if diff >= long then     --long press time in seconds       log('long press: '..diff..' seconds')      else     --short press time in seconds       log('short press: '..diff..' seconds')   end   --time the object was ON in seconds   log('object was ON for: '..diff..' seconds')       hour = math.floor((diff / 3600)+ 0.5)     if not storage.get('counter') then     counter = hour       storage.set('counter', counter)     else       counter = storage.get('counter')       counter = counter + hour       storage.set('counter', counter)     end       --total time the object was ON in hours       log('hour counter: '..counter..' hours') end
