Philips Hue motion sensor pairing with zigbee gateway LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Philips Hue motion sensor pairing with zigbee gateway LM (/showthread.php?tid=4576) |
Philips Hue motion sensor pairing with zigbee gateway LM - tigi - 10.02.2023 Hi, I purchased a philips hue motion sensor and I'm having trouble getting it to work properly. I do not have a philips hue bridge. I am able to pair the device to the LM zigbee however the status doesn't get updated. Device information: Manufacturer: Signify Netherlands B.V. Model: SML003 Device type: End device Power source: Battery Receive when idle: No Endpoint 2 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - MsOccupancySensing (1030) - MsIlluminanceMeasurement (1024) - MsTemperatureMeasurement (1026) Output clusters - Ota (25) - Basic (0) - Identify (3) - OnOff (6) In configuration I see entries for 'temperature, illuminance, occupancy and on/off toggle. Does anyone has experience with this philips hue motion sensor and knows how to use it without a hue bridge. RE: Philips Hue motion sensor pairing with zigbee gateway LM - admin - 10.02.2023 It won't work without a profile. We'll add this device to the next app version. RE: Philips Hue motion sensor pairing with zigbee gateway LM - tigi - 10.02.2023 (10.02.2023, 14:27)admin Wrote: It won't work without a profile. We'll add this device to the next app version. Thanks I'm looking forward to the next version update. I however managed to get it responding to presence, that is, the status gets updated in the zigbee devices list. I think it had something to do with making a zigbee group and trying to add the sensor to the group, which failed but apparantly activated the response behaviour in the philips hue motion sensor, before the status would only update if you pressed the button on the back. (I read something about the activation and pairing without the use of a hue bridge and use of zigbee clusters and tried that out using the zigbee groups implementation) But without a profile it doesn't update any values as you mentioned, so I'll wait for the app update. RE: Philips Hue motion sensor pairing with zigbee gateway LM - Daniel - 10.02.2023 You can try script in a meantime. See this https://openrb.com/docs/zigbee.htm See what the device is sending and if it is useful then you can trigger actions based on this. RE: Philips Hue motion sensor pairing with zigbee gateway LM - tigi - 14.02.2023 (10.02.2023, 16:02)Daniel Wrote: You can try script in a meantime. See this Thanks for the zigbee docs. Pairing the Philips Hue motion sensor (SML003) works but no sensor data is updated, I tried every possible pairing option and I figured out there are 2 options:
