Delete a script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Delete a script (/showthread.php?tid=4625) |
Delete a script - spyder - 06.03.2023 I accidentally created 200+ scheduled scripts, and want to now delete them. Would this function work if I know the id of every script? Just want to be careful not interfering with internal script behaviour... Code: --------------------------------------------------------------------------------------------
-- Delete a script
-- @param id number id of script to delete
function ScriptUtilities.delete(id)
db:query('DELETE FROM scripting WHERE id = ' .. id)
script.reload(true)
endRE: Delete a script - admin - 06.03.2023 This should work. script.reload can be called once all scripts are deleted. There's no need to call it each time a single script is deleted. RE: Delete a script - spyder - 06.03.2023 Thanks! Duplicates removed and script.reload called once. |
