KNX IP Secure Routers - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: KNX IP Secure Routers (/showthread.php?tid=4631) |
KNX IP Secure Routers - savaskorkmaz - 08.03.2023 Hi, We want to use ABB , IPR/S 3.5.1 with Logic Machine. This is a KNX IP Secure Router. Can we communicate with Logic Machine .To communicate, is it enough to check "Enable only secure communication" setting ? RE: KNX IP Secure Routers - Daniel - 08.03.2023 You must read back the Backbone key from ETS and paste it to LM then it will work. RE: KNX IP Secure Routers - batistacaceres - 09.12.2024 (08.03.2023, 10:54)Daniel Wrote: You must read back the Backbone key from ETS and paste it to LM then it will work. Where can I find the Backbone key in the ETS6? best regards Roger RE: KNX IP Secure Routers - Daniel - 10.12.2024 https://forum.logicmachine.net/showthread.php?tid=4137&pid=26702#pid26702 |
