Rotate by css fixed - Printable Version
+--- Thread: Rotate by css fixed (/showthread.php?tid=4636)
Rotate by css fixed - DGrandes - 09.03.2023
I rotate an On/Off object by css but when I click on it, it rotate to original position. Is there any whay to fix position?
RE: Rotate by css fixed - admin - 09.03.2023
Add !important to your CSS rule.
RE: Rotate by css fixed - DGrandes - 09.03.2023
(09.03.2023, 11:38)admin Wrote: Add !important to your CSS rule.
I´ve done that but doens´t work
.rotate180{ transform: rotate(180deg) !important; }
Works for me as is. See if this works:
.rotate180, .rotate180:active {   transform: rotate(180deg) !important;   -webkit-transform: rotate(180deg) !important; }
RE: Rotate by css fixed - DGrandes - 20.04.2023
(09.03.2023, 12:48)admin Wrote: Works for me as is. See if this works:
Hi!
It doesn´t work. I put this class (rotate45) in aditional class but it doesn´t work.  When i click it changes to original rotation.
.rotate45, .rotate45:active{ transform:rotate(45deg)!important;   -webkit-transform: rotate(45deg) !important; }
RE: Rotate by css fixed - admin - 20.04.2023
Which browser/OS are you using?
RE: Rotate by css fixed - DGrandes - 21.04.2023
(20.04.2023, 12:18)admin Wrote: Which browser/OS are you using?
Chrome, Mozilla and Edge.
It doesn´t work in any of them
Which one do you use?
I see that if I don´t check "Disable object click animation" on Vis. Configuration it works. But I don´t want animations on click.
RE: Rotate by css fixed - admin - 21.04.2023
Use this if click animation is disabled:
.noanim .rotate45, .noanim .rotate45:active {   transform: rotate(45deg) !important;   -webkit-transform: rotate(45deg) !important; }
