Melted 24V connections on the Logicmachine - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Melted 24V connections on the Logicmachine (/showthread.php?tid=4642) |
Melted 24V connections on the Logicmachine - stigen - 11.03.2023 Hi! ive had two logicnmachine now that has meltet in the 24V connections, one almost startet a fire, has anyone else had problems with this? Its melted on the 24V connections for the knx power. (with nothing knx devices connected) Both Logimachines are dead and not worikng. Both logicmahines are older type with black 24V connections. Its seems that the coil in knx power has started the melting.. Just wondering if this is an common thing? -stigen- RE: Melted 24V connections on the Logicmachine - admin - 13.03.2023 Can you send these devices to us for inspection? Usually such things happen when 230V AC is connected to the power input port instead of 24V DC. |
