Visu FULL-Screen mode hang up after starting - Printable Version
+--- Thread: Visu FULL-Screen mode hang up after starting (/showthread.php?tid=4643)
Visu FULL-Screen mode hang up after starting - AlexLV - 12.03.2023
my visu hung up in full-screen mode. Not so familiar with such kind of error. Where errors could be? Advice needed how to correct. How to switch wisu from start to full-screen mode taken from forum.
Part of log from Firefox:
Uncaught ReferenceError: grp is not defined     <anonymous> http://xxx.xxx.xxx.xxx/scada-vis/trends?id=1&mode=day:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=1&mode=day]trends:194:3[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=1&mode=day]trends:143:33[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=1&mode=day:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=1&mode=day:155 [url=http://172.23.77.105/scada-vis/trends?id=1&mode=day]trends:143:34[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=9&mode=day&_nc=ve67m1ltel:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=9&mode=day&_nc=ve67m1ltel]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj]trends:194:3[/url] Uncaught ReferenceError: grp is not defined     <anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069:194     jQuery 4 [url=http://172.23.77.105/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069]trends:194:3[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj]trends:143:33[/url] Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069]trends:143:33[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http://xxx.xxx.xxx.xxx/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o:155 [url=http://172.23.77.105/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k:155 [url=http://172.23.77.105/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck:155 [url=http://172.23.77.105/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn:155 [url=http://172.23.77.105/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and:155 [url=http://172.23.77.105/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j:155 [url=http://172.23.77.105/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b:155 [url=http://172.23.77.105/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8:155 [url=http://172.23.77.105/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8:155 [url=http://172.23.77.105/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj:155 [url=http://172.23.77.105/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj]trends:143:34[/url] Uncaught (in promise) TypeError: Fullscreen request denied     fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069:143     StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069:155
Alex
RE: Visu FULL-Screen mode hang up after starting - admin - 16.03.2023
Most likely the problem is caused by trends that you have included via iframe element.
Try this code for fullscreen, it will only work on the main visualization.
$(function() {   var body = document.body;      if (body.classList.contains('usermode')) {     function fs() {       document.documentElement.requestFullscreen();       body.removeEventListener('click', fs);     }          body.addEventListener('click', fs);   } });
