Scene on Mosaic - Printable Version
+--- Thread: Scene on Mosaic (/showthread.php?tid=4689)
Scene on Mosaic - CristianAgata - 29.03.2023
Good afternoon,
A simple info.... Is it possible create event script to run scene created in mosaic?
Best regards Cristian
RE: Scene on Mosaic - admin - 30.03.2023
Try this. Change title variable to the title of your scene widget (case sensitive). If you have multiple scenes with the same title then this script will run all such scenes.
title = 'my scene' config = storage.exec('get', 'mosaic30:config:0') config = require('json').decode(config) function checkwidget(widget)   if widget.type ~= 'user_scene' then     return   elseif widget.title ~= title then     return   end   for addr, value in pairs(widget.settings.objects) do     grp.write(addr, value)   end end for _, floor in ipairs(config.floors or {}) do   for _, room in ipairs(floor.rooms or {}) do     for _, widget in ipairs(room.widgets or {}) do       checkwidget(widget)     end   end end
RE: Scene on Mosaic - CristianAgata - 30.03.2023
(30.03.2023, 05:55)admin Wrote: Try this. Change title variable to the title of your scene widget (case sensitive). If you have multiple scenes with the same title then this script will run all such scenes.
Thanks admin, I will try and I let you know.
RE: Scene on Mosaic - CristianAgata - 01.04.2023
Hi admin,
tested and it works, thank you so much.
Could I suggest an improve?
It could be interesting add some delay between a command and other. It could be useful for scene that interest TV command for example.
BR Cristian
