Icons dissappear when using layout - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Icons dissappear when using layout (/showthread.php?tid=4691) |
Icons dissappear when using layout - enekofer - 30.03.2023 Hi, I'm using a layout to have the same ribbon in all the screens, but after placing icons and going to the browser, some icons disappear. It happens without a pattern, sometimes and not all of them. What could it be? Thanks for your help. RE: Icons dissappear when using layout - Daniel - 30.03.2023 Browser cache? Can you record it? RE: Icons dissappear when using layout - enekofer - 30.03.2023 (30.03.2023, 07:58)Daniel Wrote: Browser cache? Can you record it? Of course, I will test it and send it to you by PM. RE: Icons dissappear when using layout - admin - 30.03.2023 Check if you have plan links pointing to empty plans. Such plans are not rendered so plan links elements are not shown. RE: Icons dissappear when using layout - enekofer - 30.03.2023 (30.03.2023, 08:12)admin Wrote: Check if you have plan links pointing to empty plans. Such plans are not rendered so plan links elements are not shown. This! Thanks to both of you |
