Many LM to One Telegram - Printable Version
+--- Thread: Many LM to One Telegram (/showthread.php?tid=4692)
Many LM to One Telegram - AlexLV - 30.03.2023
Is it possible to send info from different LM to one telegram? I used the same TG credentials at both LM. Idea - send command like "Status" and receive info from both (many) LM.
I tried to check it and receives such errors:
* arg: 1   * string: invalid response * arg: 2   * table:    ["error_code"]     * number: 409    ["ok"]     * bool: false    ["description"]     * string: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
Alex
RE: Many LM to One Telegram - admin - 31.03.2023
Many LMs can send messages to Telegram but only one LM can receive messages from Telegram.
RE: Many LM to One Telegram - AlexLV - 31.03.2023
Yes, I understood it during tests.
Thank you for explanation
Alex
