reboot the device - Printable Version
+--- Thread: reboot the device (/showthread.php?tid=47)
reboot the device - cekca - 27.07.2015
Is possible to reboot the device from script...????
I would like to schedule a reeboot every week or month.
RE: reboot the device - admin - 28.07.2015
Is there any issue that you're having that requires a frequent reboot? The device is designed for 24/7 operation and should not require to be rebooted if functioning normally.
RE: reboot the device - cekca - 31.07.2015
sometimes the bacnet objects are not updated and i need to reebot the device
RE: reboot the device - edgars - 31.07.2015
please make sure you are using the latest firmware.
Our BacNET implementation is fully tested and approved by BTL, so all should be fine there.
RE: reboot the device-BACNET MSTP to BACNET IP - Angeles - 20.09.2016
(31.07.2015, 13:05)edgars Wrote: please make sure you are using the latest firmware.
How can use LM  like BACNET MST gateway BACNET IP.
sorry, I want use LM like gateway BACNET MS/TP to KNX o BACNET IP
RE: reboot the device - admin - 20.09.2016
Bacnet MS/TP is not supported, only IP
RE: reboot the device - Acla - 20.09.2016
(20.09.2016, 12:36)Thanks for your attention but on datasheet say "BACNET MS/TP " and BACNET IP   admin Wrote: Bacnet MS/TP is not supported, only IP
