Reading event notifications from Grandstream GDS3710 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Reading event notifications from Grandstream GDS3710 (/showthread.php?tid=4710) |
Reading event notifications from Grandstream GDS3710 - tigi - 13.04.2023 I'm trying to setup event notification for the grandstream GDS3710. I cannot use an lp script since the gds3710 only accepts an ip and port I've searched the forum for a simple resident script which is able to capture the data the gds3710 sends when an event occurs but without any luck. I've found a script which at least generates some output but not the whole body. Code: * string: POST / HTTP/1.1User-Agent: Wget/1.16.1 (linux-gnu)Accept: */*Accept-Encoding: identityHost: 192.x.x.x:7777Connection: Keep-AliveContent-Type: application/x-www-form-urlencodedContent-Length: 29Can someone point me to the right direction or alter the script below. Code: local socket = require("socket")
local server = assert(socket.bind("*", 7777))
local header
while 1 do
local client = server:accept()
local line = client:receive()
header = line
while (#line > 0) do
header = header .. line
log(header)
endThanks in advance! RE: Reading event notifications from Grandstream GDS3710 - admin - 13.04.2023 Try this: Code: local socket = require("socket")
local crlf = '\r\n'
while true do
client:settimeout(5)
local pat, len
while true do
local res, err = client:receive(pat)
if err then
break
if type(pat) == 'number' then
client:send(
'HTTP/1.1 200 OK' .. crlf ..
'Connection: close' .. crlf .. crlf
log(res) -- contains request body
break
elseif #res == 0 then
pat = len
elseif not len then
len = res:match('Content%-Length: (%d+)')
len = tonumber(len)
client:close()
endRE: Reading event notifications from Grandstream GDS3710 - tigi - 13.04.2023 (13.04.2023, 08:55)admin Wrote: Try this: Works as a charm! Thank you very much admin!
