Split Modbus register - Printable Version
+--- Thread: Split Modbus register (/showthread.php?tid=4736)
Split Modbus register - Joep - 26.04.2023
Hello all,
I need to split a Modbus register to different bits as you can see from the attached manual starting at page 5 for register 0x0107.
Below the script so far. For example register 0x0107 pH status now returns a number which makes sense as it need to be split to different bits i assume.
Modbus Manual
require('luamodbus') mb = luamodbus.rtu() mb:open('/dev/RS485', 19200, 'N', 8, 1, 'H') mb:connect() mb:setslave(1) --Hydrolyse Percentage value = mb:readregisters(0x0101) if value then     value = value * 0.1     --log(value)     grp.write('10/0/1', value) end --pH waarde value = mb:readregisters(0x0102) if value then     value = value * 0.01     --log(value)     grp.write('10/0/2', value) end --Rx waarde value = mb:readregisters(0x0103) if value then   --log(value)     grp.write('10/0/3', value) end --pH status value = mb:readregisters(0x0107) if value then   --log(value)     grp.write('10/0/4', value) end   --Rx status value = mb:readregisters(0x0108) if value then   --log(value)     grp.write('10/0/5', value) end   --Water temperatuur value = mb:readregisters(0x0106) if value then   value = value * 0.1     --log(value)     grp.write('10/0/6', value) end   mb:close()
RE: Split Modbus register - Daniel - 26.04.2023
Use value_bitmask in profile
https://forum.logicmachine.net/showthread.php?tid=839&pid=6729#pid6729
RE: Split Modbus register - Joep - 26.04.2023
(26.04.2023, 13:40)Daniel Wrote: Use value_bitmask in profile
As i'm still facing Invalid CRC errors (see my other thread https://forum.logicmachine.net/showthread.php?tid=4735) So i prefer to use my own Modbus script instead of a Modbus profile. The profile is not getting all the registers as it stops from the first one when receiving an Invalid CRC. The script is still running true so i get the info mostly.
Try this then
https://forum.logicmachine.net/showthread.php?tid=3948&pid=25477#pid25477
