Logic Machine Cloud - cannot connect to LM5 - Printable Version
+--- Thread: Logic Machine Cloud - cannot connect to LM5 (/showthread.php?tid=4740)
Logic Machine Cloud - cannot connect to LM5 - msybilla - 27.04.2023
Cannot connect to my LM5 from LogicMachine Cloud.
Sync button remains disabled. LM5 is connected to the internet. My LM5 is able to ping remote.logicmachine.net
Browser console does not show any error or warning. Neither syslog.
HW: LM5 Lite + Ext (i.MX6)
SW: 20230130
LM5
Remote
RE: Logic Machine Cloud - cannot connect to LM5 - admin - 27.04.2023
Sync button is enabled only when LM is connected to cloud. Maybe there's a firewall blocking the connection?
RE: Logic Machine Cloud - cannot connect to LM5 - msybilla - 28.04.2023
(27.04.2023, 14:17)admin Wrote: Sync button is enabled only when LM is connected to cloud. Maybe there's a firewall blocking the connection?
It may be firewall. Which port does cloud service use? 80?
RE: Logic Machine Cloud - cannot connect to LM5 - admin - 28.04.2023
TCP 443 and 8883
RE: Logic Machine Cloud - cannot connect to LM5 - xxyzz - 23.10.2024
Hi, I am struggling with the same issue and I suspect that IT has not opened the required Ports.
I used Traceroute to see if a packet reaches the cloud servers. But as far as I know, Traceroute uses UDP per default. Is that the same on LogicMachine?
How can I add the -T flag to traceroute command. Maybe in a script?
I tried to add a window that accesses https://remote.logicmachine.net, but that did not work as well. I also can't access the download server, but is that hosted under remote.logicmachine.net as well?
Thanks for your support
Kind Regards
RE: Logic Machine Cloud - cannot connect to LM5 - Daniel - 23.10.2024
First check if you have correct gateway set in network interface.
Gateway is set correctly, otherwise I would not be able to Ping anything outside my Broadcast domain.
RE: Logic Machine Cloud - cannot connect to LM5 - admin - 23.10.2024
See this: https://forum.logicmachine.net/showthread.php?tid=3263&pid=30745#pid30745
