Local connection to powerwall API - Printable Version
+--- Thread: Local connection to powerwall API (/showthread.php?tid=4751)
Local connection to powerwall API - LucioB81 - 05.05.2023
Hello everyone,
I am trying to connect to my Tesla Powerwall gateway through local network. I can get the authorization token with the following code:
When I try to get the charge percentage, I use the following code:
function getAccessToken()     IP = '10.51.10.224'     data = '{"username":"customer","password":"XXXXX","email":"my.adderss@gmail.com","force_sm_off":false}'     socket = require('socket')     ssl = require('ssl')     json = require('json')     params = {         mode = 'client',         protocol = 'tlsv1_2',         verify = 'none'     }     client = socket.tcp()     client:settimeout(1)     res, err = client:connect(IP, 443)     ctx = ssl.newcontext(params)     client = ssl.wrap(client, ctx)     client:settimeout(1)     res, err = client:dohandshake()     req =         'POST /api/login/Basic HTTP/1.1' .. '\r\n' .. 'Host: ' .. IP .. '\r\n' .. 'User-Agent: curl/7.64.1' .. '\r\n' ..             'Accept: */*' .. '\r\n' .. 'Connection: close' .. '\r\n' .. 'Content-Type: application/json' .. '\r\n' ..             'Content-Length: ' .. #data .. '\r\n\r\n' .. data     res, err = client:send(req)     res, err, partial = client:receive('*a')     local headers, response_body = res:match("^(.-)\r\n\r\n(.*)$")     local token = json.decode(response_body)['token']     client:close()      return token end
When I try to use the token with this function:
function getSoe()     IP = '10.51.10.224'     socket = require('socket')     ssl = require('ssl')     json = require('json')     params = {         mode = 'client',         protocol = 'tlsv1_2',         verify = 'none'     }     token = getAccessToken()     client = socket.tcp()     client:settimeout(1)     res, err = client:connect(IP, 443)     ctx = ssl.newcontext(params)     client = ssl.wrap(client, ctx)     client:settimeout(1)     res, err = client:dohandshake()     req = 'GET /api/system_status/soe HTTP/1.1' .. '\r\n' .. 'Host: ' .. IP .. '\r\n' .. 'User-Agent: curl/7.64.1' ..               '\r\n' .. 'Accept: */*' .. '\r\n' .. 'Connection: close' .. '\r\n' .. 'Authorization: Bearer ' .. token ..               '\r\n'     res, err = client:send(req)     res, err, partial = client:receive('*a')     log('send', res, err)     if res == nil then         return nil     end end
I get the following result in the logs:
* arg: 1
  * string: send
* arg: 2
  * nil
* arg: 3
  * string: wantread
I cannot understand what is that wantread error, how can I solve this issue? I tried in postman and it works.
RE: Local connection to powerwall API - admin - 08.05.2023
Your second script has an incorrect IP address - 1.1.1.1 instead of 10.51.10.224
RE: Local connection to powerwall API - LucioB81 - 08.05.2023
(08.05.2023, 06:18)admin Wrote: Your second script has an incorrect IP address - 1.1.1.1 instead of 10.51.10.224
Ahem my bad, I wanted to obfuscate that as well but I didn't do the first one.   Rolleyes
Should have used the right one from the start, it's in a private network anyways
