Custom Switch MDC - Printable Version
+--- Thread: Custom Switch MDC (/showthread.php?tid=4753)
Custom Switch MDC - eco-view - 06.05.2023
Hello.
Is it possible to use a custom switch such as this?
https://henan-guanjie.gitee.io/ui-design/develop/web/components/input-controls/switches/index.html
https://material-components.github.io/material-components-web-catalog/#/component/switch
RE: Custom Switch MDC - admin - 08.05.2023
Where exactly do you want to use it? The standard toggle element can be styled via CSS to have a similar look.
RE: Custom Switch MDC - eco-view - 11.05.2023
I'd like to use it throughout the visualisation. Is there an easy way for a not super technical person to style 'inline' switch to look like one of these?
RE: Custom Switch MDC - admin - 11.05.2023
Add to Custom CSS:
.toggler {   width: 84px;   border: none;   overflow: visible; } .toggler .btn-toggler {   color: transparent !important;   text-shadow: none;   padding: 0;   width: 42px;   height: 42px;   border-radius: 50%;   box-shadow: 0 0 1px 3px rgba(0, 0, 0, 0.2); } .toggler .btn-bg {   padding: 0;   width: 64px;   height: 22px;   margin: 10px;   border-radius: 11px; }
You can adjust the Control size scale property in Vis. parameters to make it bigger/smaller as needed.
That works fantastic and looks great!
Would you be able to help me out with a dimmer slider to suit?
Thank you so much
RE: Custom Switch MDC - Daniel - 11.05.2023
See this thread, you can modify it as needed
https://forum.logicmachine.net/showthread.php?tid=467&pid=2544#pid2544
