Mosaic cloud translations - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Mosaic cloud translations (/showthread.php?tid=4762) |
Mosaic cloud translations - tpospichal - 11.05.2023 Hello is there any easy way how to replace english words in Mosaic in cloud? I can do that by CSS, but maybe it can be done with more propper way? I need to replace: Main paige = Hlavní stránka Home = Domů Functions = Funkce .... Thank you. RE: Mosaic cloud translations - admin - 11.05.2023 Cloud mosaic has been updated with the same translations as LM mosaic. By default it follows the LM global language setting from the admin UI. If you change the global language you will need to perform cloud sync again. You can also set a custom language by clicking the wrench icon in the top left corner of the cloud main app selection screen. This is a per-browser local setting that has higher priority than global. RE: Mosaic cloud translations - tpospichal - 11.05.2023 (11.05.2023, 12:49)admin Wrote: Cloud mosaic has been updated with the same translations as LM mosaic. By default it follows the LM global language setting from the admin UI. If you change the global language you will need to perform cloud sync again. Thast perfect thank you wery much. |
