lm5 firmware update error - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: lm5 firmware update error (/showthread.php?tid=4777) |
lm5 firmware update error - Frank68 - 19.05.2023 Greetings I saw the new firmware and I wanted to update it on an LM5 Lite (3 DIN units), but when I try to do it it says invalid signature. Also even with the current firmware, there are packages to update MOSAIC, Allert manager, Logic Machine cloud, it gives me invalid signature for the package, what can I do. actual frmware version is SW: 20230130 A thousand thanks RE: lm5 firmware update error - Daniel - 19.05.2023 Try downloading the image and signature again, maybe it got corrupted. RE: lm5 firmware update error - admin - 19.05.2023 Also run this script once and post what you get in Logs: Code: log((io.readproc('md5sum /etc/ssl/certs/*')))RE: lm5 firmware update error - Frank68 - 19.05.2023 (19.05.2023, 08:07)admin Wrote: Also run this script once and post what you get in Logs: Solved Not say why, the LM have a wrong date and time. thank's |
