Searching for an Integrator for a job - Modbus/LM5 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Searching for an Integrator for a job - Modbus/LM5 (/showthread.php?tid=4779) |
Searching for an Integrator for a job - Modbus/LM5 - anve - 21.05.2023 Im looking to hire somebody with good experience of LM5 and Modbus TCP integration for a small job. My criteria: Experienced in LM5, High knowledge in integration of Modbus devices. Independent and solution-oriented. The job is to create visualization functionality for a Nibe S1255 heat pump in LM5 and add all modbus objects to LM5 and make a proper and reliable connection for long term use. The heat pump is connected through Modbus TCP and the modbus registry is available. Remote connection / VPN can be setup for remote work and testing. You need a registered company with VAT no to be hired for the job. Payment by invoice. Budget is discussed in PM before start. About me: Swedish Experienced integrator, High knowledge in System integration / building automation. There is also very good chances for future projects together if we find a good collaboration. Details is discussed in PM. Looking forward to hear from you! |
