HTTPS Visualization in Android Touch Panel - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: HTTPS Visualization in Android Touch Panel (/showthread.php?tid=4782) |
HTTPS Visualization in Android Touch Panel - iJAF - 24.05.2023 Hello, I frequently use SpaceLynk with Android Wall Touch Panels with no problems. I use Chrome in fullscreen to display the visualization. But since the last firmware (2.8) i'm getting a warning that is always present at visualization like in the attached picture. In the change log for this firmware they included a HTTP warning that should be causing this. How do I disable this warning or overcome this issue? RE: HTTPS Visualization in Android Touch Panel - admin - 24.05.2023 To turn HTTP back on go to System config > Services > HTTP server and set HTTP mode to "HTTP and HTTPS enabled". You might need to clear cache on your touch panel if HTTP is still redirecting to HTTPS. |
