EnOcean Antenna length - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: EnOcean Antenna length (/showthread.php?tid=48) |
EnOcean Antenna length - RSV4 - 28.07.2015 Dear all, I started using an EnOcean device and it works perfectly. But since the LM3:Reactor sits in the cellar we have some "dead spots" at home. I 'd like to move the antenna to a more suitable place which would require a longer antenna cable. Is this possible, and if yes, is there an extension available to put between the original antenna cable and the LM3? Best regards, Robin RE: EnOcean Antenna length - edgars - 29.07.2015 Hi Robin, you are welcome to use either LogicMachine Ambient or any regular EnOcean repeater for this purpose. RE: EnOcean Antenna length - RSV4 - 29.07.2015 Hi Edgars The LogicMachine Ambient look great, but since I only need the repeater function I'll go for a small repeater that I can hide in the wall. Many thanks for the idea, haven't thought of it. Best regards, Robin RE: EnOcean Antenna length - RSV4 - 10.08.2015 Now using an Eltako Repeater, works perfectly with only 0.9W standby loss. |
